Ru5ty_t00l
looking much better.
why don't u spray paint the cpu coolers top black? only the part is visuable through the window
Lol yeah I know2x 5770's, one black, one blue pcb. Totally wrong.
And yeah the enermaxes do a very good job! Getting the same temperatures as with the original noctua's. I control them with a fancontroller though (scythe kaze master pro 5,25)
Thanks for all the comments btwI'm far happier with it too.
enermax fans are boss, i have 9 in my rig - silent
1 question when you turn down the fan speed do you get a buzzing noise and do the leds on your fan start to have a spaz attack?
How about the noise? Are they any louder than the noctuas?
Looks a damn site better, still might be tempted to bring that GPU cable through the hole closest to it though, like the other ones are.
Well worth while though. and well done
Looks soooooooo much better, correct me if i'm wrong but i don't think you had to label all the cables in the 24 pin, they are all the same lol
looking much better mate!
Those cables look so much better now! Great job mate!
That looks amazing, want to do mine for me? I have no patience![]()
This is starting to look good, but there's a few things that i don't like:
The gpu's as mentioned don't look good together, an especially not in this build, the blue PCB looks awfull.
Allso the gold ocz ram don't fit the build! i would have changed it to some white vengeance LP stiks, it would look so much bether!
I allso spoted that some of the cables is posible to see throug the hole in the bottom, and it just looks a bit messy.
