Cable extensions for custom para sleeve
SparkleDJackson
Hey dudes and dudettes. I am wondering what would be the most cost effective thing to do as i need longer cables for my sstem. Buying premodded cables then stripping and para sleeving or buying connectors and wire and doing it myself from scratch. If the second what grade of wire would i need. As i was in halfords today and bought 7m o wire with a max wattage of 50. My psu is a ax1200. What should i do
Doing it from scratch sounds like a nice learning lesson. You could also get long extensions and practice on them instead. You keep your warranty then incase things go bad. Do you have any experience with sleeving, cabling and attaching pins?
Yea i dont wanna mess with my stock ones for the warranty reason lol so custom extension cables to plug onto my dtandard cables or just complete cable from psu to board etc. but yea what wattage wire will i need
