dieseldog49
Well as of right now the plan is to used a L piano hinge so we should see a full 180 degree rotation on the trap door.
While I like the idea of a raised section the problem then becomes wiring as the rear ports would all be facing me and there will be a massive amount of cables going into the rear I/O so that would look really untidy. My plan is to have nothing really visible but then have the wow factor of the trap door, a bit of a hybrid of Form and Function.
As soon as I have the x79 running in the Shinobi as a temp rig I will get back to sketchup and illustrate more of this as well as my plans for Disk drives and HDD/SSD storage plus switch and indicator integration.
Thanks again for the comments and questions guys, it is really encouraging. Also how do you embed a video on this forum?
