Ok guys, another big update.
I had a bunch of stuff show up today including my paracord
I will be using the 3 colors on the left.
My 160gb Intel SSD and Samsung 1 Tb Spinner for storage.
I also got more heat shrink, ordered a Crimp setup from MDPC. I also got deadlift1's Extensions for the DD res in.
Thanks again man they did the trick perfectly!
So with those, I had everything I needed to get this setup wet. I was super stoked so I started wiring up and sleeving the power and reset switches.
Then disaster, as I was measuring out a wire length and I bumped the latch holding the tray up and slamming it down. The heavy water blocked video card ripped the PCIE 16x Slot right from the motherboard
Now while this is frustrating, it is also entirely my fault, I had considered a better more secure latch but opted for the simpler setup. I am sad to see this mobo die before it even had a chance, I rather liked how basic the bios was and I also liked the built in buttons and display, however I picked this board cause it was on sale and I got it for a good price. I am undeterred however because I really do want to see the effects of cooling a CPU upside down and you can't try something that hasn't been done before without some risk
 .  First priority obviously is a MUCH better latch and then a new motherboard, any suggestions that will go with black, red and grey and are fairly affordable please let me know.
Well instead of posting a video of getting my system topped off with water and leak checked I leave you with pictures of a ruined motherboard but thats modding, some times it all goes terribly wrong and thats what makes it exciting
 . Now if you will excuse me I am gonna go to the gym and take my pent up rage at myself and take it out on some weights then have several pints spiked with whiskey.
