R robump New member Jun 4, 2007 #1 Hi, I have just bought a Black Ice Xtreme radiator, and i cant find out what barb and thread size or type it has. Please could someone enlighten me, so i can order some 1/2" barbs. Thanks Rob
F FarFarAway New member Jun 4, 2007 #2 I fully expect it has 1/4" so you need 1/4" to 1/2" BSPP fitments I expect
R robump New member Jun 4, 2007 #3 Thanks, is there a way you can tel whether it is BBSP or not? Also what make of barbs would you suggest? Rob
S serialk11r New member Jun 7, 2007 #5 Yep anythign that's G1/4", 1/4" bspp, will work. Even NPSM works (its a yankee pipe thread woot!), because the threads per inch number is close enough for a short threaded part to fit.
R robump New member Jun 7, 2007 #6 right thanks everybody, which brand of barbs perform best, im going to be buying loads, so i thought i might as well buy the best ones. Thanks Rob
H Ham New member Jun 7, 2007 #7 EK 1/2" high flows? http://www.watercoolinguk.co.uk/catalog/product_info.php?cPath=39_53&products_id=493 I think thats them. I got some lying about and the bore on them is big.
R robump New member Jun 7, 2007 #8 Will do they look pretty good. I will order some when i get round to it, Danger den any good? Rob
