ASUS RAIDR help
Hi guys,
My Raidr recently arrived and I planned on using it just as a storage drive for my games. For some reason it isn't showing up in Windows, nor in the BIOS. When I boot though, it does show the drive in a raid config in the post. All of the information on their site is just for if you're using it for an OS install.
Any ideas?
Just an update. I finally fixed the issue. But now I've started doing some speed tests on it, and I'm only getting 400 MB/s
CrystalDiskMark 3.0.2 (C) 2007-2013 hiyohiyo
Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
Sequential Read : 368.686 MB/s
Sequential Write : 344.756 MB/s
Random Read 512KB : 334.652 MB/s
Random Write 512KB : 361.458 MB/s
Random Read 4KB (QD=1) : 31.544 MB/s [ 7701.2 IOPS]
Random Write 4KB (QD=1) : 59.816 MB/s [ 14603.5 IOPS]
Random Read 4KB (QD=32) : 215.858 MB/s [ 52699.7 IOPS]
Random Write 4KB (QD=32) : 211.404 MB/s [ 51612.3 IOPS]
Test : 100 MB [G: 0.0% (0.1/223.4 GB)] (x5)
Date : 2015/04/03 17:06:44
OS : Windows 7 Ultimate Edition SP1 [6.1 Build 7601] (x64)
Any ideas what might be going wrong?
Thanks
You just have to install the driver when the hard drive option is missing when you install your OS
Speedwise it will be drivers or the sata port you have it on
Yeah I didn't even do a fresh install. My new parts all get here next week, I just wanted to see how this thing goes.
In regards to the drivers, I have installed all the ones that came on the disk and they say it's all up to date. I would assume it'd be the slot I have it in. It's an old mobo that had a bit of rain on it a while back (the system was off and I dried it out over a weekend). The slot doesn't even let me use GPU's in it anymore. I'm testing it on my friends Gene VII later tonight to see if that'd fix the issue
Thanks for the reply!
