Thanks for your input, I thought I had respondedKinda had the DOA feeling when I posted my post early in the thread, but didn't want to jump to any conclusions. But already there, from what had already been posted, gave me the gut feeling of probably a bad GPU. Hence my follow up questions, but didn't get a reply on those and saw others jumping in, so I stepped back.
Glad you found the issue at hand though and hope the next card will work just fine for you
This is an omen ! It means you should get the 7900XTX !
Well I have installed another new card today and I still have no image.
According to my qcode I have booted to desktop, AA no errors or beeps during boot up.
I tried safe mode with minimal and same
tried a different HDMI cable and same result.
I guess it has to be my monitor which is from 2015 (S27E510C 1080p)
And you have set the Bios to prioritise Discreet GPU and not iGPU? also tried slot 2 of your mobo?
This seems to be issue between GPU and Display.
When you turn on your computer, does it get an IP address on the network?
Plug a network cable in to check.
I suspect your OS is booting.
