Just dug out my old Mach 11 gt and recieved a 775 kit from Phil
, im building up the motherboard / kit and have a possible problem. Last time i used the prommie was with a socket A kit which had a plastic back plate, the new 775 kit has an aluminium backplate. When i line up the back on the motherboard theres a few componant legs sticking up right where the backplate sits. I'm worried that when the kit is all bolted together the aluminium backplate will touch / short these componants out. i realise that the sealstring is in between the backplate and motherboard but it looks to close for comfort once the kit is screwed together. The motherboard is a Asus P5B deluxe wifi ap, i already had to dremel the plastic top plate slightly to get the screw holes to line up correctly. on a positive note the prommie has been tucked away for at least 2 years but she fired up straight away when i tested her
