Hi,
i was having random crashes on the computer. Decided to stress test to work out the problem. Ran Intel burn test for around 3 seconds and the computer shutdown. I went to reboot and the motherboard lights just flashed and thats it.
No PSU fan, no mobo lights, nothing.
Changed for a known working PSU, same outcome.
Removed everything from the mobo except the cpu, same result.
removed the cpu so just power to the motherboard, PSU fan spins and the 'CPU fault' light comes on on the mobo.
CMOS has been cleared and motherboard is on the latest bios
Board is an Z390 Aorus Pro
CPU 8700k
RAM DDR4 3600
What i would like to know is, have you any ideas i can try? if not is there a way to confirm whether its the cpu or mobo?
CPU 8700k
RAM DDR4 3600
