RizeAllard
Now i am curious about the prices. If they not more expensive than acrylic one I thought I should change to them....
i wonder why they dont thread the pipe.. would be easier. or supply a small tap / dye set so you can thread them your self.
p.s
some sand in the pipe is just as effective and a lot less time consuming than frozen soapy water. also sand wont expand when freezing so is unlikely to split the pipe
It's not up on alphacool.com yet. I wanted to have a look at the pricing.
Edit-
Derp. Just aaw the post by alphacool, please ingore me and my stupidity.
I wonder if they will add UV versionsToo bad I just ordered my tubing for the tear down and rebuild.
CHILLAX they are not up yet.
How on earth do you plan on screwing in both ends if the pipe is threaded?
Rigid Tubing has became the latest water cooling craze, but now Alphacool's new HardTube series adds metal tubing into the mix as well as the clear tubing we are used too!
You use a simple pipe bender and copper pipe cutter for the metal tube - there will be a cutting kit available shortly.
And yes metal tubes will keep the coolant slightly cooler but not by a massive amount.
