Been a while since an update - I haven't had much time to work on this over the past few weeks, but hopefully that's over now and I can start to get this project finished! I have managed to do little bits over the past weeks, mainly sorting out my cables - just the 24pin left once I find out where it's gonna go.
I did try out using some fishing line to lace the cables together, but it was too smooth and didn't grip on the paracord like the waxed nylon that I'm using.
Enough talking. Time for some pictures:
I originally made the 8pin go straight down towards the power supply before realising it would foul the tubing. I later redid it over a mete long to route it out of the way.
It's a little messy where the 2 SATA, the 8pin and the Molex cables meet in the corner:
Hopefully I'll be able to sort that out by sewing the cables together once everything is finalised.
Moving around to the front of the case, the SATA cables are pretty much out of sight. As will the SSDs once the outer aluminium case is installed.
Keep moving around to the front and the PCI power cables add a splash of colour to the otherwise monochrome canvas.
They stick out a bit at current, which means they will probably be touching the side panel once it's on.
You can also see the 8pin poking out at the top of the case:
The 24pin cable still needs to be done. I'm thinking of routing it in front of the motherboard down between the graphics cards and radiators. It might be a bit of a squeeze and make it rather difficult to fit the SATA cables, but it's the only place where it wont be crossing over any tubing.
That's it for this time, hopefully the next update won't take as long.
