Well.... I`ve found that the thermal control on the stock RAM cooling pads sucks dyson stylee, so I had a wee think about how to improve thermal transfer to the main cooler.
Step one...disassemble card and have a look.
These crappy pads are responsible for transferring the heat away from the cards RAM. When the RAM is overclocked, I found that it would freeze the system after one game test in 3DMark- to me, it looks like the RAM is overheating.
These were cut from the PCI blanking plates that are found on cheap cases. I know something similar can be found in DIY stores and some garden centres- small and pretty thin aluminium plates- those would be IDEAL for this.
Putting the plates onto the RAM- a thin smear of AS5 onto the chips, then these will stick on fine. I twisted them back and forth a couple times to make better contact.
All in place. the main cooler had AS5 applied to the blocks that sit proud for the RAM blocks, then the card was reassembled and fired up.
So far so good....temps seem ok, it benches fine and, best of all....I didnt break anything.
Now for the new OC attempts!
Yea, not many of us are using the stock cooler, but i`m surprised/disappointed that NVidia can assemble a card that uses X million transistors, yet cant measure the spacing between the cooler and the top of the core and RAM accurately, so use thermal pads instead.
Kenny
Update: couldnt bench at higher RAM frequencies. Ah well
Kenny
