Yep. Even when I have always used a razor... I got to the point where the risk is no longer worth it. I picked up Der8auer delid tool and no more worries.
If you mark the CPU in any way, even non fatally then you ruin your chances of a return. Use the delid tool, seal the bugger back up and you get your warranty as well
It's a shame Brendan has moved to the USA. IIRC he used to charge like £5 for the service.
Delided my 7700k last night used thermal grizzly liquid metal and re sealed the IHS and now my load temps are a massive 30 degrees lower which is insane!
But I killed my 1080 ti but that's another story and won't enevr be using a kraken g10 again
That's a rounded number but I was hitting between 85 and 91degrees now I'm not exceeding 63 obviously it isn't perfect and ambient temps were different so I can't give a perfect result but I'm happy
The kraken G10 is compatible with every gpu I think but I had a freak accident with a memory heatsink I fitted that got caught under the waterblock and put massive pressure on the memory chip and now it's attracting all over the place on boot and crashing before windows
I once used thermal pads that were too thick and thought you had to tighten the screws really hard. Literally bent my 8800 Ultra like a banana and broke the solder under the GPU core was totally brown bread.
Yeah it's very painful I wiuld have rather the cpu died than the gpu £700 down the pan I actually had to hold back the tears and I'm getting flashbacks even talking about it.
