TheUnkn0wn
350D - COMPLETED
As my first water build I thought I'd push the limits of the 350D yet keep it clean at the same time. I've had to mount my hard drives vertically to make room for the 60mm front rad. I've also cut a hole in the rear 120mm fan mesh to make room for the fill/drain port.
Specification
- i7 4770K
- 16GB 2400MHz RAM
- ASRock Extreme4 Z87M
- 2 x Segate Barracuda 7200RPM 1TB RAID0
- 1 x 128GB Samsung 840 Pro
- 2 x 290X
- RM1000 PSU
Watercooling
- EK 12/16 Tubing
- 2 x EK 290X Water Blocks
- 2 x EK 290X Backplates
- EK Supremacy Clean CPU Block
- EK Monarch RAM Blocks
- EK DDC 100 Res + Pump
- EK 240x60 RAD Front
- Alphacool 240x36 RAD Top
- Mayhems Pastal White Coolant
Temps are very good, they hardly budge above 50C.
Specification
- i7 4770K
- 16GB 2400MHz RAM
- 2 x 290X
- RM1000 PSU
Watercooling
- EK 12/16 Tubing
