[Build Log] Delilah 2.0
Ahhh alcohol and impulse buying. A combination after my own heart, LOL! Having disposable income while drunk can sometimes be a curse. Looking good Lucy!
So, a few days after that disaster, the replacement pump arrived, another cracking deal on facebook :lol:
Mounting did take a little bit of expert hole drilling to get it secure..
Freehand work like this is not my strong suit and the very reason CNCs exist :lol:
So everything was done again! But then I had a couple of drinks and kept thinking about how much work i'd been putting in to a rig with a 3rd gen CPU.
So this happened..
MSI x299 Gaming Pro Carbon with an EK RGB monoblock.
No idea how i'd afford a CPU and RAM, but £200 for the pair.. I sort of convinced my self :lol:
Nice looking board, did it come with the monoblock fitted or did you do it yourself.
Very nice. That should be quite a considerable upgrade. I seriously considered x299 and a 7900X before going down the amd threadripper route. Still strikes me as daft that intel don't solder the IHS on their x series HEDT parts anymore.
I really wish I could get a monoblock for my threadripper system.
Luckily my 7820x has already been delided and redone with liquid metal :)
It's the same CPU as I had kinda. Just 4 generations newer :)
After purchasing the motherboard and monoblock, I've just been completely put of budget so I couldn't go and order a CPU and RAM straight away. In the mean time though, I've done these few bits :)
First thing was replacing the semi modular Cooler Master PSU. I know it wasn't a hugely important thing to do, but with space on this build being such a premium, the current setup of having excess cables tucked behind the pump and cable extensions bulging everywhere, it just made sense. So I picked up this RM1000X from Corsair as I know I can easily get custom braided cables for it.
I then did a bit of work running the cables for everything I could without a motherboard. Not the neatest I know, but there's a lot going on back there!
Next, I replaced that ugly (imo) GPU connector block and replaced it with two Alphacool single card adaptor blocks and once I had that roughly sorted, I finally did a test fit.
I'm really please with how well everything fills the case. I've pretty much got the same amount of hardware as I had in the HAF X I started with, but just packed in to a smaller box. I may have mentioned before, as much a I love the huge impressive towers, the empty space those builds usually have is a real pet peeve of mine. Well that and unnecessarily long tubing runs :p
All there was to do then was wait until I have the budget for CPU, RAM, braided cables and an M.2 drive.
So in the mean time, I picked up a plexi connector set for the GPUs as well as adding some white under the lenses to really make the logos pop.
Finally, I added some vinyl to the top of the cards and the SLI bridge. I've ended up getting MSI GPUs and a mobo so I thought i'd push it a bit. Plus, their dragon logo is super cool. Even if it was a right pain to cut and weed.
More to follow soon.
~~ Lucy
That's comin' along nicely, looks like you're going to end up with a completely new PC at this rate...
Thanks! What started as an intermediate upgrade has now resulted in everything being replaced apart from the front 360 rad, fittings and reservoir!
Just cutting them on a silhouette plotter.
Great thing about vinyls is they can always be removed! Makes it easy to change up the theme if I wish
Oh OK. Yeah I bet that's a fecker to pick. I thought picking a Bitspower dragon was bad enough.
Probably takes around 10 minutes. It's all about making loads of redundant cuts so everything peels off in the same direction
Yup that's the exact method I use. Get it under a spotlight so you can see it properly, then cut loads of relief cuts between the plotter cuts and remove in sections.
I tell you what is annoying.. When you spend ten minutes and then realise you've been pulling out the actual graphic. Then I go !@!!***!!!. lol. I tell you what it reminds me of on the fiddly scale.. Straightening Intel motherboard pins under a magnifying glass. Your eyes go out of focus for a second and it all just merges into one :D
I do all of my redundant cuts with the plotter! I don't trust myself freehanding razor blades :lol: :lol:
I've don't that one a few times too.. I was doing a vinyl of Mia from pulp fiction lately and realised I was weeding the wrong part. Finished it up and used it as a spray paint stencil instead!
It is damn fidley though, but compared to some of the vape stuff I do it's nothing. Working with 40 AWG wire is on an entire different level of fidleyness :p
haha vaper too, eh? That is one thing I have not dirtied my hands with yet is making coils ! I built my way up to dual coiled monsters, but found I was going through vape like crap through a goose so I just dropped back to the old single coil. I wouldn't mind, but I've got a taste for very expensive bottles of vape (like £30 for 100ml) and I was going through it so fast it almost made it not cheap any more lol.
Yeah I make all my own coils and use pretty much exclusively mech mods. I work part time in a vape store so I don't have to worry about juice and such! Mind if I ask what juice your using?
Usually imported stuff. ATM I am using Candy King Sour Worms which is a take on the sour worms you buy in the USA. Neon Nightcrawlers or something? I want to try their Swedish Fish flavour next (it's not fish, it's a red fish shaped candy from the USA). I also use Marshmallow man III which is marshmallow with a hint of strawberry, and Choco Donuts (which is exactly how it sounds). Other faves of mine are Puppie Slush grape and blue raspberry.
