Thread Tools Display Modes
  #11
Old 26-01-19, 02:28 PM
Korreborg's Avatar
Korreborg Korreborg is offline
OC3D Crew
It's an awesome case. Finnished my built in december.
But need to change the water, and the addressable RGB took me by surprise :/
You can't just buy a splitter and add more strips.
And the Phanteks D-RGB don't work with a cablemod strip
But looking forward to seeing the end result
__________________
[I9-7900X][Asus Strix X299-E][EVGA 1080TI FE][Corsair 16GB 3733MHz][Fractal Meshify C][Corsair AX860i]
[Samsung 970evo 500GB+1000GB of mixed SATA SDD's][ASUS PG278QR][Logitech G510s and G502][Steelseries Wireless H]
  #12
Old 02-02-19, 04:47 PM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
So i had sometime today , can not put it off anymore cable to be run and tidied
And before anyone comments yes i did try and do it properly or as best as i can cause i'm no artist
next is the cooling but i kept changing my mind on run , will update when Mr indecisive make up his mind
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
  #13
Old 02-02-19, 05:01 PM
Bhebhe Bhebhe is offline
Newbie
Great Build Dude. Hope to get great deals also as you did. =)
  #14
Old 02-02-19, 05:16 PM
Eddie long's Avatar
Advanced Member
thank you , as for the deals alot is just being in the right place at the right time , i was in no rush which also helps
__________________
  #15
Old 03-02-19, 07:11 AM
Eddie long's Avatar
Advanced Member
So i had a bit of a second wind last night and got the loop sorted (well for now )
I might when i feel brave enough invest in some hardline tubing as there are only 3 straight runs and i have enough wiggle room with the fittings , but thats for another day
__________________
  #16
Old 03-02-19, 07:18 AM
Eddie long's Avatar
Advanced Member
Oh an i also fitted the riser cable for the GPU on the farthest back slot so i have clearance from the side
__________________
  #17
Old 03-02-19, 06:22 PM
Eddie long's Avatar
Advanced Member
Filled loop this afternoon to flush then drained and refilled , left running for about 4 hours then checked fitting , no leaks result
Time to fit GPU and see if i have actually got this right , and the crunch question will it post ?
Yes It Posted ! looks like a fairground ride but it posted , have a couple of issues with fans not reporting rpm correctly on the included fan hub , so i will have to pop it out of the case to have a closer look later
__________________
  #18
Old 03-02-19, 09:17 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Looks great man ! Love the res. I also like how you tubed it.
__________________
If you don't like what I post don't read it.
  #19
Old 04-02-19, 09:48 AM
Eddie long's Avatar
Advanced Member
Thank you well I try, got some little gripes to sort out and to get software loaded then we we see how she proforms.
  #20
Old 04-02-19, 11:35 AM
tinytomlogan's Avatar
The Guvnor
Corrr blimey this is one heck of an upgrade dude!
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
