Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 07-08-18, 02:14 PM
SebastianAltena's Avatar
SebastianAltena SebastianAltena is offline
Newbie
Asus Directcu II gtx770 faild
After about 80h of playtime in Fallout new Vegas vsynced to 60zh @ 1080p, game started crashing, 3rd time it crashed my pc started locking up after windows7 logo. PC does boot into safe mode but there are green dots and lines all over the screen. PC will boot into windows normally, if I let it powered off for about 10min, but it blackscreens after 30min, or in seconds if I attempt to run a game.
I have tried clean installing nVidia drivers and it didn't work. I tested my 770 o a different pc and the same thing happens.
I'm running my old 8800gts now and it works fine.
Is there any way to repair my 770? I'm in a bad spot right now and I can't afford a new gpu.
  #2
Old 07-08-18, 02:40 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
You can bake it. That is about your only option if it is like that.
__________________
  #3
Old 07-08-18, 02:42 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Sadly if your 770 has reached this state of artifacting and it's proven the same on a second system then the card is ready for retirement, I know of no way to repair a card that does this it's just Silicon degredation and maybe time to consider saving for a new one. Sad times R.I.P GTX770.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #4
Old 07-08-18, 04:56 PM
Newbie
Unhappy
Thanks for the help.
Well back to 8800GTS that sucks
  #5
Old 07-08-18, 05:21 PM
WYP's Avatar
WYP WYP is offline
News Guru
Sorry to hear about your graphics card. It sounds like the GPU's silicon is going bad, as Wraith has already said.
At least you have your 8800GTS at a stop-gap, but it looks like you need to start saving for something new.
__________________
_______________________________
Twitter - @WYP_PC
  #6
Old 09-08-18, 12:58 AM
Newbie
Question
Could power supply have killed my gpu? I have Corsair tx650 from 2012, it's cool and quiet, I didn't have any problems with it, but it's old. Should I replace it when I get a new gpu?
  #7
Old 09-08-18, 01:11 AM
AMD Enthusiast
It can but does not seem like it did in this case. It is mostly likely the memory on the card just failing. It's usually the first thing to go on a GPU.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
