ZenModz Builds.
ZenModz
Hi all,
My name is Ken Byrnes AKA ZenModz. It's my first time here. Ive been a case modder for a bit over 2 years now, still very new to modding but have pick up other skills not PC mod related, that has help me get in to PC modding. From the first mod I did I got hooked, And I'm not holding back on my builds. I don't just Mod PC,s
I would like to think I take them to the next level. I have done all kinds of art for over 35 years. from game design, 2d/3d design and texture art as well as airbrushing, modeling, wood work, metal work. plastic fab. and more.
I hope to get to know you all in time. And I hope I get to bring that Wow factor to your screen.
Cheers, Ken.
To start off the Fallout 4 case mod. Has had about 900 hrs spent on it. Was build on a supper low budget. The hole build cost under $1,500.
» CPU: I5 4590 @ 3.80 GHZ
GPU: GTX 590
MB: ASUS MAXIMUS VII FORMULA.
RAM: 16GB DDR3-(11-11-11-30) / G.SKILL R.J. @ 2100mhz
» PSU: Cougar CMX 1000w
Storage: OCZ agility 3 240gb @ 2tb hdd.
Case :Silverstone FT02
Some photo shop work to bring the case into the game.
Caps are made from new beer bottle caps.
No 3d printing just hand made. No steel was used all rust is hand painted with acrylic auto paints. using a paint brush or airbrush.
Next up is my last case, This one is a scratch build.
And is called Power Cell. this build is themed around Star Wars.
Case Height 730mm. Width: 430mm.
Case Shape: cylinder. One base, One top, 3 Pillars, 3 clear windows.
MoBo:Asus H97I-PLUS Mini ITX LGA1150
GPU: ASUS TURBO GEFORCE GTX 960 OC Edition 2GB-GDDR5. Running on a 2x 30cm PCIe cables
CPU: i5 4690k
RAM: Gskill 2400
PSU: Corsiar HX1000i
SSD: OCZ Trion 100 240GB
Water Cooling:
: One custom 60mm x 400mm res.
: 3x 120 slim rads, EK
: CPU block, EK :Pump, EK.
: Fittings, Monsoon.) Hard line Monsoon.
: Custom water blocks 6x90mm W 20x20mm H,D clear blocks running 9x5mm Round 650mm L tubing. on the out side of the case as part of the loop.
: Lighting: Black Light, and some white LED's.
: Fluid: Neon Green, EK UV lime Green.
: Fans 6x Corsiar 120mm and 1x 200mm coolermaster.
Thanks to ASUS for suplying me with the MoBo & GPU for the Power Cell.
Thank you for looking, If you have any questions don't be shy I'm he to tell all, If you want to know how things where done just ask. :)
Cheers, Ken.
Thanks Excalabur50 thanks for having me. And I must say that's a cool name you are using. Big fan of the movie and more.
Wowser! Those are 2 epic builds, 10/10 for the power cell, 8/10 for the Vault 111 build.
I adore the case work on Vault 111 but the internal hardware looks out of place with it being so clean and fresh, there is no doubt you have mad modeling and paint skills. Kudos to you dude.
Cheers, Wraith. yes I get that a lot about the inside. I might change up the hardware later. and go to town on the inside on day.
Nice way to showcase your rigs dude ! Good to see you here too :)
Are lol thank you Alian. :P
Nice builds there Ken and welcome to OC3D :)
Thank you Tolemac. :)
