Hi,
So I've found a stable voltage and I want to move from manual cpu voltage to adaptive.
When I move the setting to Adaptive Mode then input the voltage into the Additional Turbo Mode CPU Voltage, the PC will not post at all with a mobo code of 96.
The mobo is an Asus Rampage V extreme.
I've tried entering a higher voltage into the box which I know will be more than sufficient. And still it won't post.
Is adaptive broken on x99 or something?
I've left all the other settings below it set to AUTO.
I just have the CPU core voltage and ram voltages set.
BCLK is set to 125 as this is what XMP sets it to.
Any suggestions please to what it might be?
Thanks
EDIT:
Seems to be something to do with having BCLK at 125. At 100 it posts.
Any ideas?
Thanks
EDIT:
Any ideas?
