This is my own fault, but after stripping down the Mach for cleaning, i`m now trying to put it back together for a couple runs, but I`m a bit stuck with the cabling to the compressor.
I made notes that say the neutral cable connects to a vertical spade-type pin on the back of the compressor. I`ve found this spade pin (theres a "12" underneath it) but theres a copper wire connected to it and the paddle grip on the neutral wire wont fit over it. Am I trying to put it in the wrong place?
Sorry for being so crap..I thought the notes I was taking were good enough, obviously they weren`t.
Kenny
Can get a pic up if you need it
Kenny
