Aaaand Nothing. It's stuck at Q Code 98 and won't go any further. I've swapped out keyboard/mice, used all the USB ports available (except BIOS), swapped RAM, Went to single GPU using both PCI-E slots, flashed BIOS, Cleared CMOS, and still nothing past Q Code 98.
I do eventually get this screen, but no keyboard/mouse capability...
I love the build, but that SLI block is quite horrendous!
you did a good job on the recolouring. Have you thought about repainting the aluminium colour on the gpus for a lighter/darker shade of purple for better contrast?
I agree with you about that SLI Bridge- it's hideous. It's a temporary solution until the one that I want comes back in stock.
I was toying with the idea of painting the GPU's, but I kind of think that it would be too much color. Instead I've got an SSD on order which will go underneath the ROG emblem, but I plan on using an acrylic cover for it with a contrasting color.
I got the SSD and custom cover installed. I'm in contact with someone who is able to do a custom back-lit cover that I can use instead of the ROG emblem.
The last thing afterwards is waiting for the SLI Bridge that I really want to come in.
