wireless headphones
the_bone_reaper
ok i am looking for a wireless headphones for under $500 if that is possible i really do not want a big bulky mic and stand. i have been looking in to getting the steelseries h wireless gaming headset. i really dont want the Corsair Vengeance 2100 because i am not a big fan of Corsair gaming gear
so as much help as you can please and thank you
i got a set of turtlebeach z300's which are epicly good and pretty cheap tbh cost me £109 uk which is about $160 us comes with a usb dongle and a usb/micro usb charger >>
http://www.turtlebeach.com/product-detail/pc-headsets/ear-force-z300/369
i did want the z7xp400's for the color but at the time they were out of stock i got reccomended these and i cannot fault them there miles better than my trittons the z7 is also £100 more... but does come with a box to select between channels etc and swap between pc/ps4/xbone etc..
if you dont want a set with a mic take a look at the sony ones here >> http://store.sony.com/wireless/cat-...;sid=uuMUHuUxUv4uHrfDvxdtGn071a9RbywK9CaH39mw
yer ok the turtlebeach z300's are $269.95 here in Australia and sony ones are not what i am looking for any was i for got to put the price of the steelseries h wireless $379.00
I just bought the Sennheiser RS180s, which are absolutely bloody brilliant.
These are headphones only. If you want to use them as a microphone too, i suggest you get them and a modmic.
hey guys i have chosen a headset and it has been completely won over be the SteelSeries H Wireless gaming headset and i think it is worth the money but that for the help
