Will these rads fit an utgard
Deceit
Member
I'm looking to eventually get these rads below if suitable when can get the cash up and was wondering would anyone know if two of these would fit in an utgard. It says max it can get in the roof is 46mm thick but hoping could squeeze that extra 1mm into it. Also would the second one fit in the drive bay. I have a disk drive in the top and the 3.5" drive bay is right below it. Has anyone on here put a rad in there below like that? I'm thinking it might need a hole cut in the drive bay for the top of the watercooling where the hoses connect to.
http://www.specialtech.co.uk/spshop/customer/product.php?productid=10693
what rads ?
The ones in the link.
They are EK CoolStream XT 240mm Dual Radiator : XT 240j
I posted the link about 30secs after putting the ad up, was quick to get in before I did that
Youll have to measure the front yourself, the roof would be a gamble without the exact rads I wouldnt want to say.
I did the measuremeants and it only has exactly 240mm space there
. The rad is 276. I dont think am going to get a dual 120mm rad that only takes up 240mm so think have too come up with something else
I could fit a thick 280mm rad along the bottom and put two 140mm fans on but only half of the bottom was designed to take a fan so part of it wouldnt be able to get air from outside, would this make it not worthwhile as I really wouldnt be confident in cutting the case. I could also have a fan at the front pulling air in on top of it though.
45mm is the largest rad you cant fit uptop. And thats still a sqweeze. That means just the rad no fans uptop you to mount them inside the case under neath.
If you havent' bought a case yet just get the cooler master advanced lets you mount the thickest rads on the bottom with push pull
These are the limitations for the utgard: Radiator size limitation inside of top panel: (L)320*(W)160*(H)46mm. I have the case already, if didnt would still buy it as is a really good case for the money. I'm thinking with the rads size being 276 x 123 x 47mm could could file off the under side of the plastic housing thats on top of the case a little too help fit that extra 1mm, dont think that will be too much of a problem and on the underside I have 2 140mm fans which are good enough for me which you can see here:
If that doesnt work will fit one of these 280mm rads, its much thinner but hoping the extra size will help a bit
http://www.specialtech.co.uk/spshop...lth-280mm-Dual-Radiator--GTS280-pid-5609.html
