Which PSU
equilibrium
Hey guys ok.... I am in the middle of redoing my pc at the mo. It will consist of everything in my sig but will have 2 water loops instead of one. I do overclock and bench so it needs to be stable :) I dont want to spend masses so something reasonable. Any good recommendations for me? Cheers all
DAve
thx for that kenny ;) I was thinking of the seasonic 600w. Are the pcp+c bigger than std psus? I mean in length etc as they look beastly lol.
Cheers
DAve
Depends what size you are after - the 510 and possible the new soon to be stocked at EPUK 750w units are the same size as other models.
850w and 1kw models are monsters. The FPS 700w might be a better choice of whats available now..... I'd probs wait for the PCP&C 750w first though.
The problem with the seasonic unit is the number of 12v rails it has - sometimes the power split is a hindrance.
Thanks for the info there Mav :) Ive been looking at the fps 700w but like you said i think i may wait and see what the pcp&c 750w has to offer ;)
DAve
Phil,do you have the dimensions of the new 750 pcp+c ? and if possible how many 12v rails ?
Dave you could also look into the OCZ 600W, Silverstone Zeus 650W, Enermax 600W & Zippy 700W having said that the PCP&C would most probably be best.
