Hey, doing my first build, I have already got the Ryzen 5 3600 cpu.
I am looking for a motherboard to go with it. I figure some of you are running the same cpu so you could give me some input on some decent boards ready to go with it. I am trying to keep the cost down on this build, I do not need to go rock bottom bargain bin, I want a decent quality board, but not looking to pick up a performance $300 board either.
I am considering perhaps the MSI MPG X570 At $170 (US) that is about the max I would spend on a board for this build.
I also had another question with this as well, The cooler that comes with the Ryzen does not look like it would do to great a job so will be using something else, not ready to go to water just yet, I was wondering if I would be able to use my old Noctua D15 on the ryzen and a new board? I am not sure if there would be any issues. Will the new boards have the same holes for mounting and will the clearance onto the chip be ok? It has been a great cooler and I would rather use it for now over the one that comes with the ryzen.
Anyway, thank you for any input.
