Which one !?!?!?!?
Bogel
805 will OC beter as thats just how intel rollls ;)
Especially with a new 965 board vs the old 945/955 that were around in the 8** series times. I would suggest though, dropping a bit more for a 920/930.
this computer will only be in my hands for a week tops. My sister wants vista, and i simply refuse to spend 100$ on a operating system and put it on a celeron d (Will be getting yelled at for it running slow). But I will just save up and try and get a slightly better one i guess, also, conroes are still to expensive for my liking, this is going to be a budget computer 1gb ram and a cheapy 256 card for aero. conroe really isnt needed for internet browsing in my opinion...anyways thanks for the help.
Id go for the 805 and oc the nuts off it:). altho the 915 is practicly the same price, same stock clock speed but 65nm iirc.
