mr_fishbulb
I was trying to fix a machine last night and found out that the CPU fan power plug on the motherboard wasn't supplying any power. When I hooked up one of those molex pass-thru things and plugged the CPU fan into there, the machine boots fine.
Then I remembered I'd set the voltage trick on the molex to 7v when I was using it with my old case fan.
Should I swap it back to 12V to use it full time with the CPU fan?
