Ive always used masterkleer?
Take a look at CKC matey thats what I used in there. Nice and clear, very shiney too. Works well. Mayhems Pastel doesnt react with it either.
Duralene is the favorite right now.
Primochill is not the greatest for clear right now.
Hmmmmm from that it looks like primochill is better then. This could be good for some long term testing.
From that thread it does, however, the thread was created on December 31, 2011 which is white a while back now so Masterkleer may have changed their 'recipe'. My Primochill in 'Nuclear Fission' still seems to be going strong after months of use, but I will drain the loop and dissect the tubing to see the inside of the tubing.
EDIT: I may buy a bit of clear Primochill tubing and throw it in some distilled water for a while
I also found this massive thread dedicated to "Plasticizer Problems" which shows that pretty much all tubing has 'issues'
I have read about this on other forums but there is a lot of misinformation and accusation.
Maybe this would be a good community thread,personal experiences and testing coming together? Would be a good resource of our own.....
I will NEVER buy Primochill again. Here's what my blue Primochill looked like after 2 weeks:
http://i1236.photobucket.com/albums/ff449/papasmurf6768/Computer Build/IMAG0542.jpg
And I'm not alone, there's a huge thread on OCN called something like "Plasticizer Issues Discussion" where a ton of other people are saying the same thing. I bought some Duralene to replace the Primochill, it's looking great after 16 hours![]()
What we need are small 3" lengths from all the major manu's that we can subject to controlled conditions mimicking PC use...
I was using only distilled water with a couple drops of Primochill Liquid Utopia. I had a SKC ready to go but after doing some reseach I thought those are what were causing the problems, so I didn't end up using it. I installed it and had the loop running within a week of buying it I'm pretty sure.
Yeah because 8 months ago LRT was different... Now it sucks!
