D
Deleted member 9280
Guest
Will be most likely be building my new first WC system near Mid-Feb. I was wondering what colour I should use in the coolant? I would like it UV and would anyone suggest a good FAN to brighten this coolant up?
Also what hose/tubing is the best? And is it best to use the coil around the pipes?
Cheers
Cheers
