WD Green 1TB, very slow write?
Just bought and installed 2x 1TB WD Greens.
Im using these as backup drives for photos/music/etc.etc.
Right now im trying to back up 101GB worth of data into these two drives, not at the same time.
From my 2TB external(USB3), connected through USB 3 from the I/O at the back, it starts off at around 90MB/s then eventually reaches 20 then 10 and lower, pic:
Trying to backup the same set of files/data, this time from a 1TB Samsung F3 Spinpoint(SATA2) plugged into the SATA motherboard header, i get around the same write speeds eventually:
Is there something wrong with the Green drives?
Why is it so slow?
EDIT: Oh the WDGreens are connected through the motherboard's SATA 3 headers.
EDIT2:
I think one of the drives has died.
1. Its not being detected in BIOS
2. If i try to boot, it takes forever, i think its waiting for the green drive to respond.
3. I have 'Hot-Swap' in BIOS enabled, and if i go to plug it in while booted, 'My Computer' freezes
4. I did 'initialize' the drive before i was trying to write stuff on it, through Disk Management so it if formatted.
5. I open DiskMan now and i cant even do anything to the drive:
Large file's transfer much faster than very small file's especially when you are trying to send 25 thousand files at a time+the green drives are slow 5500 rpm up to 7200 rpm (variable rpm) there not made to be fast thay are made to spin less to save power.
I thought of that, so i tried copying a movie to it ~1.5GB, it still went sub 10MB/s
But i think the drive has died, look at my EDIT2 on first post.
How would a 1TB Blue stand up next to this performance wise. It just so happens that as I was reading this thread I was on a website pricing these very drives. Now I'm thinking "Thanks for the warning!! I wont get a green!"
Both drives happen to be the exact same price.
Blue is much faster than a Green. Green is for power saving and Blue is for quick storage access(though the black is still faster).
How fragmented is the driver? Could be that the driver is looking all over the place for the files.
I have a green drive too, i get anywjere from 10 to 100 mb/s
I have since returned the Green drives as they were too slow for my liking, as stated above, it was going down to <10MB/s.
So i swapped them for blues, blues are great, no slow write BS cause of it being 'green'/'power efficient'.
I was sustaining 95-120MB/s writes, i dont know if the drive i was copying from was acting as a bottleneck; i was copying from a Samsung F3 which is a SATA-2.
Acoustics wise, the blue was a little bit louder, and i mean a little. But it didnt really matter for me as it was plugged into the hot-swap bay for max 2hrs just to manually back up files and i'll probably only do this twice per month.
Hope this helps.
