imported_mrbios
right, im definately buying watercooling again soon, but going to stick it on the graphics card this time, was going to try chilled water for a change as well, now i was wondering what sort of condensation proofing and other precautions ill have to take with this? virtually the same as with my mach2?
im going to set it up so the only pipes going into the case will be 2 pipes going in through the back and under the card, at the temperatures of chilled water would i need any sort of condensation proofing on the back or is that sub zero only? (i suppose the actual gpu temp wont be going below ambient even though the water will be)
are they higher maintenance? need filling up more often? and are they ok to use 24/7? the only card thatll be under it will be an audigy 2 zs so im not to fussed if thats goes pop, though i might make a little plastic gaurd to stop any water from dripping onto the board if a leak occurs
final question is it really worth using chilled water if im not going to vmod it? (i dont think i could trust myself with a soldering iron and a £300 graphics card, at least.........not yet
