Right, So a little update. Been super busy with work and with study so haven't had much time to do the desk. Even though the updates are getting smaller, the desk is nearly finished!
to do-
*Fan wiring from rad 1 to rad 2
*Keyboard tray
*Cable Management
First things first,
www.computerlounge.co.nz sponsored me some replacement Black SATA Data cables to replace my red ones and also an NZXT 2m White LED Kit so thank you very much for this!
Anyways! I started with wiring up my GPU cables. measuring every wire, and not one being the same length. A long process however well worth it
Since double cables are the such a pain in the arse I soldered them in just for extra security as the "wings" do not bite into the top wire because of the 2-wire thickness
A long while later the cable was done! Just to make sure the measurements were accurate I put some rubber bands on them. This also helps "train" the wires so that they stay like that.
Both wires done, took me about 3 hours...
Time to sleeve! When sleeving double wires you lose the general sense of where the sleeve has to end up, and you can't really use a sleeving tool to line it up either as 16awg and 18awg would need different spacings etc *blah blah blah* TL;DR: I mark some lines to where the sleeve needs to go to with a sharpie, meaning an accurate result every time!
I then use a "dummy" connector to put the pin in while it is still hot. This comes in really handy when you have done the bottom row of double cables. Instead of trying to push ANOTHER double set on the bottom row, it is good to have the dummy connector. It lets the shrink cool down, and set with the "box" shape so that it will be easy to slide into the proper connector without deforming it.
Finished cable
Don't think I need to elaborate too much on a basic Sleeving FAQ. For any help look at Lutro0 on YouTube. You will never need to watch another tutorial after watching his
Midway through the 24-pin
Done! 3.5 hours of sleeving results in one 24-pin... lol
Cables in and doing a test fit. Very happy with how it's looking!
NOTE: I will probably be using the Modsmart cable clips for about 2 months. Then take them off. This should allow time for the cables to be trained and need no supports. It will be super tidy, was considering cable lacing them but personally I think it doesn't look THAT great. Trained cables needing no support will look much better
That is all for now, will have the build done by 1st of September I promise!
Phil
