Firat
ohh god im so jealous.....my money aint going the right place !!!![]()
Thats a good looking rig, Love the Blue.
here is 5ghz stable at 1.4v with LLC (loadline calibration level 10) stable![]()
will not be running at this Speed just thought id see if i could break the 5ghz barrier for my self well technically it was 4998mhzdamn bclk![]()
im working on a 24/7 4.5ghz clock at the lowest temps![]()
Congrats sir. Add another megahert?
i will try later but for now looking for A stable 4.8 ghz in bios i put 1.36v and LLC level 10 but on load im getting 1.391v and my temps are in the high 70's ... good or badd?![]()
why go water if your only going for 4.5 you can do that on a D14, atleast go for 4.8ish![]()
4.5ghz is more than enough for what i do, i want this rig to last for a while and im sure 300 megaherts loss wount be a noticable difference![]()
50Mhz you won't notice. Anything more and you do (well I do anyway)
In my case it's not worth the extra Volts, I like my 55-60 degree load temps.
It's super fast anyways so no need there I mean 4.8ghz is tempting but id rather the CPU last longer then anything, 4.5 seemed like a good number![]()
Done - testing it now but I'm at 4.8ghz with average temp of 58 on load across all 4 cores![]()
I didn't know water was so effective![]()
I reckon you could get a brag frequency of 5.5 if you really wanted - but isn't worth the risk in all honesty
