Phil Stanbridge
Just a word of warning for those of you using a hacked or beta bios with your motherboard and attempting to run a Mach II. Don't if you can help it!
I have had a couple of Mach II's come back to me recently with corrupted firmware - the unit fires up as soon as you connect the mains and you have no control over it. The ONLY fix is to re-flash the firmware - easier said than done in some cases. Some do not even work after that point without my intervention.
So for those of you with a hacked or beta bios, be aware that if you flash the firmware you might run into problems.
