Visual basic: Adding a progress bar
mrapoc
Basically I want to add a time-based progress bar purely for appearance.
I know i need to either make a loop or, use a time based command. My lecturer didnt want to go that far but hes pleased im experimenting and wants me to have a go at home/do some research.
Im basically just trying to see how many simple yet cool things i can implement.
Heres is my code, you can probably guess what it does if you know how to add this damn progress bar!
Public Class Form1
Private Sub ButtonPress_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ButtonPress.Click
'gives a message related to user's name and shows time
LblOutput.Text = "Hello, " & TBInsertText.Text & ", Would you like to see a cool picture?"
LblOutput.Visible = True
TheTime.Text = "The time is: " & TimeOfDay
TheTime.Visible = True
End Sub
Private Sub TBInsertText_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TBInsertText.Click
'blanks text from box when clicked for user input
TBInsertText.Text = ""
End Sub
Private Sub ButtonPress_MouseClick(ByVal sender As System.Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles ButtonPress.MouseClick
'makes button visible after pressing "press me"
PictureButton.Visible = True
End Sub
Private Sub PictureButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles PictureButton.Click
'Makes picture button blue when pressed and makes progress bar visible
PictureButton.BackColor = Color.Blue
ProgressBar1.Visible = True
End Sub
End Class
Cheers
something along the lines of
// create progress bar
ProgressBar pb = new Progressbar();
container.add(pb);
//fill it over time
for (pb.value = 0; pb.value < pb.max; pb.value++) {
thread.sleep(100);
I don't know VB but im sure you can work out the equivalent. If not look for a tutorial somewhere on the web, google is your friend.
I have been trying for ages but it just doesnt seem to work at all :(
Ill have another mess around but im not sure
Hmm that I could...like edit out the gif in my sig, put it in then set a timer to initialise the next part soon as the bar fills?
Ill need to get my lecturer to help me with the timer/loops command needed
*** Uses a Guerrilla bomb deployment tactic***
Booooooomm!!!!!!!
*DIE Crap Programming Language*
