Vista Help!
Jojo29
Ok, before i start here is the list of all the parts of my new computer:
Motherboard: ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard
Processor:Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor
Heatsink:ASUS Triton 81 92mm EBR CPU Cooler
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
Hard Drive: Seagate Barracuda 750GB 7200 RPM SATA 3.0Gb/s
Graphics Card: HIS Hightech Radeon HD 4870 1GB
DVD/CD Drive: SAMSUNG 22X DVD±R DVD Burner with LightScribe Black SATA Model SH-S223Q
Power Supply: Antec NeoPower 650 Blue 650W ATX12V / EPS12V SLI Certified CrossFire Ready Modular Active PFC Power
Operating System: Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
Case: Antec Nine Hundred
Mouse: Logitech G9 Black 5 Buttons Tilt Wheel USB Wired Laser 3200 dpi Gaming Mouse
Keyboard: PS/2 Logitech Keyboard
The problem i am having is during install, it freezes. Sometimes it freezes on the first grey bar, and the farthest i got was 25% of installation. I've left it overnights to be sure it wasn't just installing slow. What could be the problem? I've already looked on the webs for some help, but most of the stuff that was said to do, namely bios changes, was already automatically set to what was recommended....I am stumped, not sure what to do to resolve this issue.
On a sidenote: there were some tiny swirl type scratch marks on my Vista Disk, could that be the problem!? I mean, they were pretty tiny enough to maybe pass but they are noticeable..
Try washing the disc with washing up liquid and dry with a lint free cloth.
Is the system overclocked at all? what sort of temperatures are you seeing in the BIOS?
run a ram test on your system. search google and download "memtest". burn to a cd and boot from it. Let it run for a couple of hours.
In the bios temperature it didn't go past 29C, it would go between 28-29C but i dont think it hit over that, is that too hot?
Nope thats fine. Have you tried cleaning the DVD? If not, try toothpaste and a soft cloth. Sounds kooky but it works (cheers Jim for the heads up on that one BTW:))
Well i got the thing running guys. I can't believe what it was. I connected my SATA Hard drive into the SATA_E1 connector on the mobo instead of the SATA_1...simple..but thank you all for all your suggestions
