Hey people i'm new in this forum. I am planning to build a PC, but i'm kind of struggling because of the so many choice out there and i dont if the part im planning to use are gonna meet my needs for now or later. I don't really plan to upgrade my pc for like 3+4 years, so i'm taking the best component right now available so they "hopefully" last a long time. Can anybody give my tips if my rigs is good enough for that.
I actually moved from console gaming to pc gaming because....well you know better frame per second, higher resolution, and other thing that console game doesnt have "yet". I'm still used to the controller so for the mousse i definitely need help if whether it is worth buying evn though i know i might not use it often
Budget: None
Purpose: High-End Gaming ( emulator too), music, video editing, school work (of course
Components/Rigs
Case: NZXT Phantom 630 Matte Black
CPU: Intel Core i7 4770K 3.5GHz Socket LGA 1150
GPU: MSI GTX 780TI GAMING
HDD: WD Green 2TB IntelliPower 64MB Cache SATA 6.0Gb/s
SSD: Samsung Electronics 840 EVO-Series 120GB
Dvd Reader: LG Electronics 24X SATA Super-Multi DVD Internal Rewriter
POWER SUPPLY: Corsair RM Series RM - 650 Watt 80 PLUS Gold Certified
Memory: G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
Memory Cooling: G.SKILL FTB-3500C5-D Fans
CPU Cooling: Corsair Hydro Series Extreme Performance Liquid CPU Cooler H100i
Motherboard: Gigabyte GA-Z87X-UD3H
Fans: Corsair SP120 and AF140 Fan
Keyboard: HP K1500 Wired Keyboard or Thermaltake Tt eSPORTS MEKA G-Unit
Mousse: RAZER DeathAdder
Monitor: ASUS VE278H 27in Widescreen LED Backlit Monitor Black
OS: Microsoft Windows 8.1 - Full Version
Controller: Razer Sabertooth Elite Gaming Controller
Headset: Razer Electra Over Ear PC and Music Headset - Black
Things I need help for
- Remove unnecessary component or make a better suggestion on
- Good color choice
- Compabilty
- PSU is not overkill or better suggestion
- If i should consider gaming mouse or regular mousse since most of the time i'm gonna use the controller after just moving from console gaming to PC gaming
- If i should add more gb in ssd or hdd
- Finally, if it gonna last about 3+4 years and the rig is upgradable.
- whether i should consider SLI
Thank You in advance
Budget: None
Components/Rigs
- Good color choice
- Compabilty
