Cigarjohn
Sorry, I haven't posted on here in a long while.
Although I do watch almost every video that Tiny Tim Logan produces as I get constant email alerts of his great, informative videos, I hardly post on the forums unless I need some good advice from all the experienced PC builders out there.
Which brings me to this posting. I need some advice on my next PC build which will be in the late Spring to Mid Summer of 2016 depending on the new technology coming out.
Here is the break-down on what I will be purchasing for this build.
My budget is around $10,000.00 or less. Preferably less. My goal is not to build an exact $10k rig but I want to give some freedom to my build.
The new Intel 750 series 1.2 TB Non-PCIe card slot version. For all my games. Might partition it for some productivity software.
If I go with an additional M.2 as a windows boot up drive, I would partition it instead of the Intel 750 and put my productivity software on it instead.
Windows 7 64
Processor? 4, 8 or the new 10 core that supposed to come out in 2016.
Motherboard: X99 or Z170? Preferably ASUS. It all depends on the advice I'm getting from the forums.
GPU: Waiting for the new Pascal Video cards to be released. Want two for a SLI Setup.
PSU: Probably an EVGA 1200 Super Nova P2
DDR4 RAM: 16 gigs, possibly 32 gigs. Again need advice from the experienced builders out there. Have many questions that need answered to the best of their knowledge and experience.
I will be using my older Viewsonic VP2655wb LCD monitor which has a 27" screen size from top left corner to bottom right corner. And will be setting graphics at 1920x1200 at 60hz refresh rates.
I also will be using my existing external water cooling system on the CPU and dual video cards. Koolance: ERM-3K3UC - rated at 2400 heat watts.
Now I know what most of you are going to say, "Two video cards for just one monitor that's under 30"? Yeah, I know it's way overkill, but to be honest, it's kind of like peace of mind for me. I've had many video cards from Nvidia when they did make video cards back in the 80's that have failed me. I did have an Alienware custom system built 11 years ago that had dual 6800 Ultras in it and one of the cards did burn up after a year while under warranty with no overclocking. And had them replaced with two 7800's which one of the cards lasted 2 years before burning up as well. So I figure; with two video cards, if one dies on me, I still have another card to use until I get the damaged card replaced. And also I won't have any gaming downtime. Peace of mind, that's what I'm mainly after and willing to pay the price for it.
On another note: I will be using my newly system for PC Gaming and will be overclocking my processor and video cards. Most likely concentrate more on my processor for overclocking.
The productivity software I most use is Word, Excel, Powerpoint sometimes and Adobe Photo and Video editing software. I play many disc games as well as online games such as: GuildWars2, Battlefield4, Starquest 2, Company of Heroes 1 and 2 and Warframe to name a few. I mainly play with others in my gaming clan.
So here are my questions: All advice given would be greatly appreciated.
1) Motherboards: There's so many different types out there to choose from. One can build an Enthusiast System as well as a Gaming System. I've had two gaming systems in the past. One custom from Alienware and one that I built that recently stopped working due to the Antec PSU HCP-1200 that decided to die on me. Very thankful that it died before the warranty was over. Unfortunately, the free replacement, HCP-1300 was DOA so I'm waiting for it's replacement to be used in a backup system build.
So I was pushing towards a more enthusiast build, but a non-enthusiast build would be fine as well.
2) Processors: Definitely 4 cores unlocked with hyperthreading. But will my gaming benefit with a 6, 8 or more core processor? And if not, what would benefit with more cores.
3) DDR4 RAM: Is there a minimum speed I would need for better stable overclocks? Was looking at 2400mhz but should I go for 2666 or 2800 instead?
Also; latency, I see latency levels from 9 to 16. Does latency really make a difference in games or overall performance?
And what about sticks. You can purchase 1 to 8 sticks to achieve 16 gigs or more memory. For example: 32 gigs of ram. Is it better to purchase two 16 gig sticks, four 8 gig sticks or eight 4 gig sticks. Does it make a difference?
And from my internet research, it seems that 8 to 12 gigs is sufficient for games. My built system used 16 gigs and was thinking to trying 32 gigs for my next build if needed.
4) PSU: Any advice between multiple rails and a single rail. I'm sure this would be a bias answer as I'm sure both are good and up to the users preference.
5) GPU: 2, 4, 6, 8, 12 gigs of ram? What's needed for gaming and the future of gaming. Also Mhz speeds for gaming as well.
6) And finally, OS: I'm happy with Windows 7 64. I've never used 8.1 and now we have 10. Is 10 much better for gaming or should I stick with 7. My windows 7 Ultra isn't supported anymore but I see that windows 7 Pro will continue to be supported to 2019. So I will be purchasing win 7 pro.
Here is the system I was using until my PSU died on me:
Lian Li PCX2000F Case
Asus Miximus IV Extreme Z68
Intel i7 2600k
Mushkin Redline 16 gig (4x4gig sticks) 7-8-7-24-2T
Two EVGA GTX-580 Classified Hydro Copper
Three Crucial M4 256 SSD's
Asus Xonal Xense Sound card
LiteOn Scribe Blu-Ray Burner
Antec HCP-1200
Logitech G510 Keyboard
Logitech G502 Mouse
Logitech G13 Gaming Mouse Pad
Windows 7 64 Ultra
Creative Soundworks 7.1 Speaker System
Koolance ERM-3K3UC external liquid cooling
Whoever takes the time in reading my post and giving me advice, I want to thank you for your time. Any advice given will be greatly appreciated. I'll accept all advice given, even if one individual has a conflict with another individuals post. Your PC building experiences and what works for you is what really matters to me and for my future builds.
Thanks again and I hope this post finds all of you with good health as well as many years of prosperity.
Windows 7 64
Intel i7 2600k
Antec HCP-1200
Logitech G502 Mouse
Windows 7 64 Ultra
