I wanted to know what anyone thinks about using a t-adapter in a liquid cooling loop. I was considering using one but have a question. Let's say you run liquid from your water tank to the pump, after the pump you split the line wit a T. One into the CPU block, the other to the GPU block..now, after that I want to bring both lines (from the output of the cpu and gpu blocks) back together again. This is where i was thinking it may be a problem??? I know you can easily split off 1 line into 2 lines, but now I want to bring 2 lines back into 1 line and run it to the radiator. Would this be a problem of any kind as you are doubling the flow and putting back into 1 tube, in effect reversing the T? Any ideas?
