S_I_N
OK! So I got the new 780T case and I'm stumped on rads. At my disposal I have in the XT45 (45mm think for those who dont know) in 360mm 240mm and 280mm. I can easily put the 360 in the roof the 280 in the front and the 240 in the floor. Only problem is that the 240 will only be able to have a single fan on it. I dont mean push or pull I mean 1 fan ONLY. As the 280mm sits down far enough to prevent a fan on the other spot. I also have arriving tomorrow another 360mm rad that I was going to use for my backup rig (AMD 6350) cpu only loop. The rad arriving tomorrow is a XSPC EX360 which is 35.5mm thick.
So whats y'all thoughts on rad placement?? I know it'll look cleaner with the dual 360's and thats my plan for later is to get 2 UT360's (60mm thick) rads. But budget is tapped atm and I really want to get my main back up and running.
OH! I should mention I'm cooling a delidded (but not nekid) 4770k @4.5GHz @1.260 vcore and xfired 7970's running the GHz bios not oc'd cause they have never been a need to oc em lol.
