Tube Bursted
looking at tht pic of the tubing I'm sorry to say but it got hot and ruptured there is no other real explanation for why that tube is swollen like that. firstly you'd of noticed it being a bad spot while pushing the tubing on it would of tried to collapse secondly the only way for it to balloon out like that and not return to shape afterwards is if it was heated. I'm thinking your pump fails causint the block to heat up and the hot water weakened it and made it burst.
I think it was a catalogue of problems, the perfect storm if you like.
Guess 1:
Say the pump stalled and was generating heat of it's own in to the water. The water isn't flowing any more because of the pump so the radiator isn't cooling it down. As the heat increases so does the pressure (adding certain additives will raise the boiling temperature, ie engine coolant above 120C). That pressure has got to be released somewhere; in your case the weak part of the tubing. The warmer the tubing gets the softer it becomes.
Guess 2:
Talking of tubing, I don't like how your tubing hangs off the cpu block. Looks like it's collapsed slightly and no longer "full bore". That in it's self could have caused your weak point. The rupture looks to be in the area where the tubing has folded/compressed. When the tubing became warmer and softer, perhaps different parts of the tubing changed tolerances at different rates. I'd suggest replacing your tubing if you can as it may have been stressed in other places and address the issue of the way the tubing hangs off the cpu.
Just my speculation of course!
Got the PCB, next week I will give it to someone to solder it for me,i can repair headphones and stuff but i dont want to risk ruining it since the model I have needs a wire extention and i will see if i can put a potenciometer to regulate the pump speed
