I did not expect such a quick answer.
i know that they do not clip together, anyway what puts me off the most is the need for a second case for the drive cage, if i could purchase them separately i would not mind an attempt at modding in order to make everything fit.
As for the massive case option this is what i have been trying to avoid by going with the R5. I had a look at the nanoxia deep silence 6 case as well (yes is an old model) but its depth is prohibiting for me.
Anyway thank you for you time. Keep up the really good work,
would these cages fit from the xl design case which are sold on there own
http://www.fractal-design-shop.de/index.php?a=289
