Hey guys
Been thinking about my new rig for 2012.
I use my PC mainly for gaming and photoshop with a bit of video editing thrown in.
This will be the 5th pc i've built and first time water cooling and as such i've decided to only do a CPU loop.
When it comes to building a new rig the aesthetics take priority, then noise and finaly performance (I still like a high end rig though^^)
The colour Scheme I have gone for is White and Black with hints of Red
Case: NZXT Switch 810 White
Motherboard: Asrock Extreme4
CPU: Intel 3930k
RAM: Mushkin Blackline 2133 16Gb (4x4Gb)
GPU: Asus Direct CUII Top 7950 Tripple Slot
PSU: Corsair Gold AX 850 psu or Seasonic P1000W (Really like the look of this PSU)
SSD: OCZ Vertex 3 60Gb Boot Drive
HDD: Western Digital Green 2TB
Bitfenix Red 24pin Alchemy Cable
Bitfenix Red 6pin Alchemy Cable
Apogee HD White CPU Block
Phobya G-Changer V1.2 360mm Triple Radiator : G-Changer 360 V1.2
Phobya Balancer 150 Reservoir Black Nickel
Laing D5 (MCP655) Vario 12V Pump for 1/2" ID Tube
Bitspower 1/4" Thread Compression Fitting Black
Mayhems X1 Premix Fluid for Water Cooling 1 Litre : BLOOD Red / UV Red
Primochill PrimoFlex Pro LRT 1/2" ID - 3/4" OD (13-19mm) Tubing : White
NZXT 120MM 9 Blade Rifle Bearing Fan 47CFM FN-120RB x3
I'm mostly concerned about the water cooling parts as this is a first time for me, so any advice will be greatly appreciated
Thanks in advance
CPU: Intel 3930k
Thanks in advance
