Thinking Coolermaster 840
I changed the TIM for MX-3 and put everything back together, its been running about 15 minutes now here are the temps:-
Temps are slowly creeping up, does the MX-3 need time to settle?????
Side panel of the TJ-07 is still removed
I'm guessing its a little better, as my pc has been on constantly for 8 hours or so, since I changed the TIM and these are the temps its Idling at:-
Fan is running at constant 60% (so maybe no better???)
Ok, IIRC the gfx temp your having prblems with. A simple way to see if case airflow is insufficient is to just take the side panel off. If the temps don't get much better then the cards are just hot cards. My brotehrs gtx295 gets up to 80c in game! Look at reviews the gtx295 is a very hot card and the Asus Mars version is even hotter!!
