Rastalovich
U get the recomendations and those template things, that give the impression that a postage stamp sized splodge is kinda what`s required.
Seeing 50million replacement hs a year, I`ve noticed manufs moving to 3 really thin stripes - quite a difference. But then they`re probably using different stuff to what they used to.
Compounding all this, I see a reviewer, and obviously an oc`er, applying 1 "squeeze" across the cpu, about the width to cover the cores underneath, but about as thick as spaghetti - and that`s it. Obviously these type of people would be a strong banker to follow.
Myself, I`m thinking u apply either of the above, the pushdown of the hs is going to moosh it all out to the sides in anycase.
I can see the reason for the spaghetti strip tho if ur doing lots of reviews with the same Scythe type hs tho.
What do u do ?
What do u do ?
