Theres a hole in my bucket....
Surfie
Hi all,
Well, it's not actually my bucket, but it is my radiator...
Any hints or tips on how to plug such a hole until a replacement comes in?
And before you ask, no- i don't know how it formed. If it had been on the fan side of the rad, i would have said "because I'm an idiot and screwed the screw too far", but this hole is on the res side of the rad, no screws there. So no ideas on how it happened.
All help is greatly appreciated.
TBH without putting something properly nasty in there no. Well, unless you can find the leak and solder it shut. Do you have a pressure tester? if you do then put the bugger in a bowl of water and pump it up.
