OK so I've ordered all the bits for The Duke's build and should be arriving hopefully tomorrow or sometime in the week, minus the bits that are on backorder. Totally stoked as I haven't upgraded in ages and this will be a complete new build woop
Anyway, the spec...
CPU: AMD 64 X2 6400+ Black Edition (stock 3.2GHz)
MOBO: MSI K9A2 Platinum AM2+ 790FX
RAM: 4Gb OCZ Reaper (4x1024) PC2-8500
PSU: Tagan EasyCon 530W Modular
GPU: XFX 8800GT XXX 512Mb
HDD: 2x 36Gb 10krpm Raptors (RAID0), 2x 300Gb Seagate (RAID0)
CASE: Thermaltake Armor Black
LCS: Laing DDC-1T Pro, EK-Supreme CPU, XSPC R120-D, XSPC Res, EK-FC88GT, 1/2" UV Blue Tubing
The bits on backorder are the 8800 and the water blocks which kinda puts a downer on things as I can't proceed with the build until they arrive.
I have a long term plan for the build also which is; eventually replace the 6400+ with a Phenom X4 when the high-end stuff comes out, maybe get another 8800GT and run them in SLI (which will require another water block) and in the shorter term get an X-Fi card instead of using the 5.1 onboard sound chip.
I will post up pics as soon as I start building
Anyway, the spec...
