Suggestions
fmgod
I have about £400-£600(more if need be) to whack on a complete new system top to bottom except monitor so I need everything from case to CPU, what can you guys suggest as I'm more to upgrade very old machines and make them Windows 7 such as Pentium 4's etc.
I will mainly be using it for Football Manager, Photoshop, Itunes, Firefox, lots of things running at once basically.
Thanks been a long time lurker
Also would take any suggestions for a decent keyboard and mouse as mine are useless the only thing I have in place is a good monitor as the old system can go as most of it is archaic or getting there.
The thing is I don't need the graphics to be tip top, Football Manager is hardly graphics cutting and only rarely do I use PS, would sooner ramp up the Processor to an i5 or i7 Sandy Bridge?
then look at the system i linked to then choose a diff GPU the cpu,mobo,ram,cooler is the onlything thats a bundle the rest can be changed
5770 is about £100 or a 6850 or 460 for £150 that will bump the price down. Try and spend as much as you can stretch as it will be more future proof.
Cheers guys, I love my music what would you suggest for that, it will be listened to through headphones.
onboard sound is 'alright' you can get an ok sound card for £20-30. The asus xonar range has some cheapo ones which perform, creative ive had some issues with drivers but I dont have a massive knowledge on recent ones. I use a yamaha o1x
I've decided on an I7 SandyBrdige with 8gb Mushkin ram, what else can people suggest to go with it include mobo, gfx card, psu, case, fans etc
Depends on your budget but heres what i personally would get
Mobo: gigabyte P67A-UD7
GPU: GTX 570
PSU: Corsair tx750
Case: NZXT Phantom
Fans: Noctua/NZXT
Heatsink: Noctua NH-D14
Mobo: gigabyte P67A-UD7 - £280
GPU: GTX 560 - £210
PSU: Corsair tx650 - £65
Case: NZXT Phantom - £105
Fans: Noctua/NZXT
Heatsink: Noctua NH-D14 -£60
well with all of that comes to £660 leaves you 40 to spend on extra fans
What you think of this?
BitFenix Survivor CORE, Black, Mid Tower Case with Handle w/o PSU
750W Coolermaster RS750-ACAAE3-UK GX, 80 PLUS, 85% Eff', SLI/CrossFire, EPS 12V, 120mm Fan
Intel Core i7 2600K Unlocked, Socket 1155, Sandy Bridge, Quad Core, 3.4 GHz, 8MB Cache, 95W, OEM
Coolermaster Hyper 212 Plus, 4 Heat Pipes, with 120mm Quiet Fan LGA775/1155/1156/1366/AM2/AM2+/AM3
8gb Mushkin
Asus P8P67 Pro, Intel P67 Express, S 1155, PCI-E 2.0 (x16), DDR3 2200(OC), SATA 6Gb/s, SATA RAID
Corsair TX Series 750W ATX2.2 SLI/Crossfire Compliant Power Supply - 70
Coolermaster Elite 430 Midi Tower with Window - Black - 35
MSI P67A-GD55 Intel P67 (Socket 1155) DDR3 PCI-Express Motherboard - 110
8GB Patriot G2 Division 2 Edition (2x4GB) DDR3 PC3-12800C9 'SandyBridge' 1600MHz Dual Channel Kit - 70
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM - 195
EVGA GeForce GTX 460 SC (SUPERCLOCKED) 1024MB GDDR5 PCI-Express - 125
Total - 720
just found this which is pretty good but you don't get the fun of building it yourself http://www.aria.co.uk/Systems/Gaming+Range/Gladiator/Anarchy+GTX+P67+Gaming+PC+?productId=43228
ah i thought you had the cpu and ram already
2600k dont know where you can find the 2600k for 199 but thats worth it
8Gb Mushkin Ridgeback pc3-15000 £115 aria.co.uk
Msi p67A-GD55 again for 110 thats worth it
Corsair tx650w £64 aria.co.uk
Xigmatek Midgard £51 aria.co.uk
noctua nh-d14 £60
Asus GTX460 1gb £130 overclockers.co.uk
total 730
depends what you prefer tbh
