name='Ham' said:
Well, take a look at
this
Yeah ok, but that is the 745.. I already knew it was rubbish.. I was planning to buy the new TMG radiator, the new M5 pump set and the new Vulcano CPU block.. not the old stuff from Tt that is in the 735 / 745.
But it's not that I say it's the best on the market, it's far from.. i just want an basic LCS for around €250,- (/£170,- /$330,-), with everything on it.
I already know I don't get Danger Den quality, as example, i just need a simple LCS set with everything on it (Radiator, Pump, CPU/VGA/NB block, Temp probe / Flow indicator ..j/k).
Those four products that you mentioned are already around the £100,-
..Than I need a Radiator, CPU Block, VGA Memory block, Temp Probe, Flow indicator etc. up the £100,-...
I don't want to spend more than €250 on it,, maybe €300 .. but not that mutch higher
Hmm, maybe handy to post the specs, what he needs to cool?
Around June he needs to cool:
Intel Core 2 Duo E6600
something like the X1950XT ..Or,,suggestions? (around €240)
Besides that, i know the Volcano 4008 is just the Copper W1 block with an big fan on it .. but I liked the Tt Big Typhoon very mutch and this is just the LC version of it, am i right?.
And about the Radiator,, which Radiator can fit on the back of the Armor?
(photo of back) ..or can just any radiator fit there?
