My windows has been acting so slow lately...
Ive even resulted in restoring bios to default (after not being able to boot i admit, at times I was getting 5 or so beeps, it then would not do anything)
So thats at default, ive turned off windows candy, and got rid of that vista thingy that comes with objectdock etc..
Spyware doctor found no spyware, it was also using high a mouts of cpu/memory so i uninstalled that. I've used equk's reg patches to take off extra services and add tweaks etc.
Outlook express loads slower than it did on my sempron! It always has. My computer has now decided it does not want to run company of heroes (audio stutter, move the camera it seems like fps is below 10!)
I have the latest catalyst drivers and audio (after using driver cleaner too). I also use ccleaner to clean off temporary files, diskeeper to defragment regulary and tuneup utilities to fix disk errors etc.
Startup takes ages, not being able to do anything although the timer has gone (usually takes 1 minute +) which it didnt a while ago. I've got 60gb free on my 200gb drive, so its not that. This general slowness is starting to annoy me
p.s - My cpu hits 52 on stock while running intel thermal analysis tool, was hitting 65 while overclocked
Might I have to redo the as5? It rests at around 40 while not under heavy use.
